Hi all.
I am in the process of designing my own fully symmetric bench power supply. It will go from 0 to around ± 70V @ 3 amps.
The voltage controls will be floating, while the current limiters probably will be in respect to true gnd of the main supply.
The whole thing will consist of 4 internal supplies to make it all work. 1x 75-0-75 and 3x 15-0-15 DC. One of the 15-0-15 will share gnd with the
75-0-75 main supply. The two others will be floating, which is where I am a bit lost.
I cant wrap my head around to to make the tracking work between the two floating supplies. The only thing I can think of is to
create some variable current sources in the common 15-0-15 supply, and pull that current through a resistor in the floating
supplies. That should work, but it somehow doesnt feel right.
I dont need mcu control or programmability. I just want to turn one reference voltage from true gnd into the same voltage on
each floating supply. I have thought about using a stereo pot for this, but the channels usually dont track too well on pots.
I also havent found any info on this, nor could I find any schematics on this issue.
Any insight on this is welcome
Thanks in advance
Jørgen
Thanks in advance
Jørgen
