hi, can i use sysasiam 5-3 amp into 4 ohms speaker? is there will be any problem? thanks.
S space2000 Member 2008-03-08 2:11 pm 2008-04-14 3:39 am #1 2008-04-14 3:39 am #1 hi, can i use sysasiam 5-3 amp into 4 ohms speaker? is there will be any problem? thanks. ••• More options Share
MikeB Member 2004-04-09 3:21 pm Gütersloh www.lf-pro.net 2008-04-14 8:28 pm #2 2008-04-14 8:28 pm #2 If you keep the +/-36v power supply there is no problem. Btw, it's SymAsym, not symasim... Mike ••• More options Share
blueskynis Member 2007-08-02 3:36 pm Niš 2008-04-15 12:12 am #3 2008-04-15 12:12 am #3 Maybe it's a good idea to double output stage power transistors when driving 4 ohm? ••• More options Share
