Greetings,
There are some sweep tubes that have G3 separate from the cathode connection. Is there any advantage to having a small positive voltage on G3 instead of grounding it? On the tubes that have G3 separate, some of the tube sheets suggest 30 or so volts.
Thanks,
Ray
