not trying to sound like a smart a#@
wow, flashing lights and blowing fuses usally means you have some open resistors in your bias circuts, usally caused by either a shorted cap, or shorted tube.
moving the tube group to another side of the amp would help determine if the tubes caused the problem, if that side of the amp starts to spark, and different fuses blow, you know that you have burned out some resistors on that side of the amp board.
simple tests with out a tube tester. pull all your tubes and mark where they cam from. find a way to get them tested. someone near you has a tester. what city/state. back to your amp board. with the tubes out and unit unpluged, check you resistors for open circuts, and your caps for shorts. open resistors are hard to identify by visual inspection but easy to find with a mult meter. while your in there with a meter, double check your diodes.
don't put the tubes back in til you get the tubes tested, and you find out what is going on , on the amp board.
main thing is if the fuses were never over sized, any fixes should be easy and cheap. I had an amp recently that was blowing fuses, root cuase never found, but an open resistor was, the fuse was oversized so I was worried about tranny damage.
when replacing resistors take note of the watt rating. if you pull out a 3 watt resistor, but only have half watt and/or 1 watt resistors, 4 series paralleled 1/2 watt resistors will give you 2 watts while keeping the same resistance. which would be fine for the short term. don't put a 5 watt cement resistor. if you line in the nyc area, I can lend you a tube tester. or you can bring you amp over, and we can go thru it real quick. good luck.
