I am planning to use multiple Sure Electronics TK2050 2 x 100W boards each connected to an apple airport express and a set of speakers to create a multi room audio system. I am currently running a board off an old printer power supply as a test system but want to buy a more long term solution.
I have seen users that have used a "laptop" power supply such as the one here 12V 0-3A DC Power Adapter 5-2.1mm Plug/AC 110V/AC 220V_Plastic Power Adapter_Boxed Industrial Power Adapter and Chargers and Transformers_Measure Power Adapters_Sure Electronics' Webstore but have also read that the Meanwell power supplies are really good. There is a difference in cost $13 vs $45 upwards.
Most of the time the boards will be powering background music. Therefore, what power supply should I get, the speakers will be max 100W, probably going to go with some 65W ones. I am also not an expert on sound. What power supply must I buy so that the system will work correctly? Also, how many boards can one power supply handle or should I only use one power supply per board?
