Supravox 215 Signature Bicone
You don`t get enough bass from a fullranger in a plain panel that is so narrow. Supravox use a 285 as sub. Use a broader panel with resonating side walls or a Rondo enclosure if it has to be so narrow in your room.
You find the picture of my resonating baffles in the Ciare 250 thread. The material for the front is polymer concrete, but I would use sandstone the next time (much more beautiful and even better). Side walls are 6mm poplar with five layers of hard laquer inside and outside. You pictures of the Rondo at http://www.auditorium23.de, also some other very interesting baffle construktions ("Bauvorschläge...").
Have you also heard the Ciare CH250? And how do they compare?
