Hey all, I hope you can help me...
I'm taking a 6-month backpacking tour of Europe next year. I have been making my own binaural recordings using a Marantz MD recorder and a pair of home made earplug mics using Panasonic WM-61 capsules.
While the quality I'm getting from this setup is terriffic, there is no way I'm lugging that recorder around with me! Besides, it chows batteries like mad.
So I bought a Creative Nomad Jukebox 3. I'll be putting a 60GB hard drive in it to replace he 20GB it comes with. This will hold most of my music collection, plus be able to record. It's the only high-tech device I want to have with me...
Anyways, this things does a pretty nice job of recording. It should serve me well in making good binaural field recordings all over Europe! Here's what I need from a mic preamp.
1. Unbalanced - It's only going three feet up to my ears. I'm already doing this with the Marantz with no detectable noise.
2. Portable - Perhaps two 9V batteries for a +/-9v split supply?
3. Provide at least 2V power to the panasonic capsules. This is easy, as I'm already doing this for the Marantz with a simple passive battery box.
4. Compact - I like the Altoids tin idea. I made a headphone amp with two 9V batteries in one.
What do you think? Would a premium op-amp be good enough or should I go discrete? I can do the op-amp design no problem, but my skills are not honed enough to do a discrete design myself.
There are lots of good schematics out there for mic preamps, but they are usually balanced.
Thanks for any help...
Here are a bunch of mic preamp circuits.
http://links.epanorama.net/links/audiocircuits.html
Also checkout Rod Elliot's web site he has 3 projects involving mic preamps.
http://sound.westhost.com/projects-8a.htm
Phil.
Phil.
I am going for this one with one of my mics http://sound.westhost.com/project13.htm , an Audio Technica AT822 for live recordings with my Minidisc. I asked Rod himself and he said the amp will happily run off a pair of 9V batteries in series (18V) drawing only a few mA. And very low noise for the money. I don't see any other design that could beat this in that way.
Could you put up a quick post on how you made your AT, binaural, "earphone" mics? I have seen them for sale and thought of aquiring them for my DAT. Of course if I could make them..... 🙂
Thanks!
Thanks!
there are some neat low voltage, low noise
single supply amps on virtually all the websites ( www.analog.com , www.nsc.com , www.ti.com , www.linear.com ) . I wonder what's in an I-POD ?
