Hi, a friend of mine wants to sale his eqiupment (pics below) and claims its all working and never been repaired.
1)Panasonic equalizer
2)Technics Stereo amplifier
3)A pair of JVC 12" 3-way Subs pair (Original)
The surround on one JVC sub is replaced due to slight wear and tear ... Its working fine !
The cut you see on one surround is the new one !
Please advise how should i check the equipment and make sure its working on its full potential and also guide if there are any known problems with any of the components of the eqiupment.
Thanks.
And admins please move the thread to appropriate section if its in the wrong section.
Sent from my GT-I9300 using Tapatalk
Thanks.
The cone surround of one of the bass units looks to have a cut or slit in it. Tweeter look a bit suspect (finger damage
To test the other stuff just see if it all works as expected and that all controls function correctly. Unless you are prepared to put it through a full test with proper test equipment then that is about as much as you can do.
Yes one of the bass units are damaged. What do u think i should be paying for this? (There may be currency conversion issues but its oka u can qoute me a price)The cone surround of one of the bass units looks to have a cut or slit in it. Tweeter look a bit suspect (finger damage)
Its worth what someone will pay
The speakers are not worth much, maybe £8 in that condition. I wouldn't pay more than £40 or so for the amp and it would have to be 100% unmarked for that i.e. in a condition that would clean as good as new. The graphic maybe £30, same applies about condition.
