Succes!
I just finished watching "The Ring" and "Die Hard 3" on my projector! Was soooooo cool! My girlfriend was so impress 😎
No hot spots, really bright, no heating problem on a 4h working time. Thank to my split fresnel and my "super" table fan.
Setup and cost:
Elmo a305-SD ------ 106$ shipped
Reburbished Nec LCD 1545V ------ 345$ CND, so ~250-275$ US
Plexiglass 24*18" ------ 5$
Wood for screen frame ------ 2$
Bolt, nuts, steel plate for screen frame ------ 10$
Vinyl window shade from homedepot ------ 30$
Total of --------- 403$ US
I'll try to borrow a camera so I can show you my setup
The only thing that I don't like is that my top fresnel is bowed, so I get a little curved picture. But it's not really noticable when I watch the dvds. I doesn't have hot spots, heat problem, and I can see the whole lcd, so I don't care about the curved picture lol!
yeah it was.
The curved picture was present with fresnel glued, but it was less visible. Like I tough, since light pass in the lcd evently, it doesn't make the center heat like glued does. With the table fan it's just perfect. The side where the fans blow is cold! the other side is a little warm. And I can see the entire lcd
And corners doesn't focus too well since it's bowed, but I don't really care.
With my setup, I don't have to raise my projection lens or lower the light, and my bottom fresnel is 9" exactly from the light. Focus like a charm.
And like I said, if I sandwitch it between 2 plexis, my bowed top fresnel will be flat like a paper sheet. So.. All problems solve, and any problems remaning!
Nice pictures of your setup, get a tripod and turn off the lights! Thats the best way to get quality pics of your setup. I can't wait to get my stuff going and take pics of everything. One of my main hobbies is photography so I hope to get some real good shots up 🙂
Don't disappear! Keep us updated on what you're doing. Do you have an enclosure to prevent light leakage? You'll probably get better contrast/etc. if you do.
GJ gui,
Btw how much distance do you have between the fresnels and the LCD? And how hot does it get?
-rep
the lights were off lol, look at one of the result pics, you can see the light from the exterior.
For the light leakage.. I'll paint the back of the plexi, and glue cardboard panel to block it.
For the distance between the lcd and fresnel.. It's about ½" on both side.
light leakage... ahhhh, it's a little more then leakage! 🙂
You really have to watch when posting pictures. No one has posted good pics yet except for YWH... which is why everyone thinks he's the only one that can do this right!
If the pictures dont come out good....
Dont post them 🙂
I'm not trying to be an ******* here... but I didnt see any results with the pictures you posted.
Dont post them 🙂
I think you should post some picture even if they are bad. There's always a lot to learn from other peole mistakes and success
