I just picked up four EV DL15X drivers that I was hoping to use to build some passive subwoofers (two or more). The problem is that I don't know how to interpret the specs well enough to figure out what size cabinet might work well with these. Any suggestions or advice is welcome.
I'm hoping to match them to a set of JBL LSR32 monitors. The JBL's go down to 60 hz, so I figure the EV's should be able to supplement them well enough to 'fill out' the sound a little more on the lower end, but I'm kind of lost beyond that.
I'm thinking of experimenting with an active crossover for the subwoofers, but that is something I will also have to figure out as I go along. If plate amps would be better, then I'm open to that as well.
Thanks.
Thanks.
