My Ambiorix sub (see thread) is finished. It just needs a few layers of paint. 😀
This brings me to the next part of the building process: amplification!
Right now I'm using an old Kenwood KR-5600 tuner-amplifier of 2*45watt RMS hooked on to my PC's sub-out.
I designed a 130mm*310*310 space under it's downfiring vent for an amp.
My original idea was to build a 100watt/8ohm, 200watt/4ohm monoblock from amplifier modules available at an electronic-parts shop in the next town. However, it seems a 180watt/4ohm module kosts 116€, AND it needs an extra protector cirquit (5.35€)and toroidial transfo (61€) to work! (I assumed the modules were class D ...) --> and more important: All prices excl VAT (BTW in Dutch) 😡
Total price for that would be well over 100€, and it probably would'nt fit under the sub anymore!
So I started looking for a plate amp for under my sub. I found on a German site a "Detonation 50" amp, 240*180*80mm, that has 100watt/8ohm, lowpass filter, phase knob, hi-and-lowlevel inputs etc ...
For 79€ (without shipping kosts) it has a lot more usefull stuff than if i build one myself and let the PC do the math.
Or not?
i searched the forum for some hints on sub plate amps, but I could'nt find where to buy <100€ amps in europe.
Anyone has other tips or better ideas?
Or not?
The only other German contenders I could find are the Mivoc AM80 and a module by Conrad. Look for them underCordraconis said:... but I could'nt find where to buy <100€ amps in europe. Anyone has other tips or better ideas?
http://www.lautsprechershop.de/hifi/verst_mi_en.htm
or
http://www.speakertrade.com/site/products/proddisplay.php?product=Mam80
for the Mivoc
and search at www.conrad.de for Artikel-Nr. 301043 - 62 for the Conrad module.
Rudolf
Thx for the reply, but it seems these amps have a built-in boost, and my design is flat till 30Hz ...
I found some more info on the Detonation 50 here:
http://www.lautsprechershop.de/hifi/index_en.htm?/hifi/verst_en.htm
Very nice curve ... however ...
Do you think I could set (change a resistor) the subsonic filter at -3dB @25Hz in stead of 30Hz? If you combine the rolloff from the Ambiorix and the amp I'm affraid i might lose the lower 5Hz or something.
Building a 100L enclosure and then losing some of the lowest bass ...
Maybe with the programmable bassEQ, but there seems to be not much more info about that?
Cordraconis said:... but it seems these amps have a built-in boost, and my design is flat till 30Hz ...
I hope your "flat till 30 Hz" is including room gain. Otherwise you will experience some boomy bass!! 😱
And don´t fret about the 5 Hz difference. You may be glad that the amp is rolling off @30 Hz - one Monacor SPH-212 doesn´t move that much volume.
BTW: What did you mean with "these amps have a built-in boost"? I thought they had a built-in roll-off!
"Das Aktivmodul verfügt über eine Tiefbassanhebung von +3 dB bei 38 Hz, wodurch man seine Gehäusevolumen weiter verkleinern kann."
From your second link@speakertrade ... I never studied German, but it is rather similar to Dutch. Could be mistaken dough. 😉
And the -3dB point is indeed 30hz in free space! Did you see the size of that thing? (last pic in the Ambiorix thread. 😀) The room it is in is about 4*6meter ... no booming bass noticed so far.
I modeled 100dB with about 10-20 watts input, and that should be more than enough, but I'd like it to be from as low as possible. the SPH-212 should sweep that @10watt.
Thx for the tips!
But I won't fret about those 5Hz any more, promise!
Cordraconis said:Did you see the size of that thing? (last pic in the Ambiorix thread.
Yeah, it´s quite a bit of furniture 😀
"Das Aktivmodul verfügt über eine Tiefbassanhebung von +3 dB bei 38 Hz, wodurch man seine Gehäusevolumen weiter verkleinern kann."[/B]
You are right. I see.
And if it rocks the house - nice for you. 😉
BTW: By judging the discussions I could follow, the Detonation modules are regarded higher quality than the Mivoc or Conrad ones. Owned a Detonation module myself. 😀
