I’m working on another floppy drive turntable motor. This one is the Jumbo 5.25 drive. I thought the motor would run on 5 volts like the 3.5 floppy. That didn’t work so I tried 12 volts, no go. If I use both voltages together it runs. Using two voltages really complicates a simple project.
I need a solution if there is one.
BluesMagoos
BluesMagoos
Measure how much current it draws from the 5V rail, then use a regulator from the 12V rail to make 5V. (You need the current measurement to decide whether the 5V regulator needs a heatsink.)
As far as I recall, all 5.25" floppy drives used +5v and +12v rails.
I cannot remember seeing any with only +5v or +12v .
Andy
(owned a computer repair business for 9 years)
Andy
It seems to me that a lot of the old floppy drive motors were either stepper motors or servo controlled with a an external speed sensor on the flywheel.
The disk spin motors are 3 phase brushless (blm) 360/300 rpm. The read/write motors are steppers. Hard to find disk motor projects, stepper motor projects are many.
Dual voltage is the working answer. 12V plus 5V makes it happy.
Beware of bad bearings in these motors. About half of my motors have bad bearings and are not usable (noise). My good motors run my TT fine. I’ve ordered some new bearings.
Thanks for the replies on the dual voltage question.
TC
BluesMagoos
TC
BluesMagoos
