Hello,
I was wondering if anyone had any advice on damping/stuffing PE cabinets. Since they are completely assembled with entry only from the front and with the shelf brace inside, access to placing damping materials is somewhat limited.
I am wondering if I can get away with placing the polyfoam in just the back chamber, behind the shelf brace, and using damping and foam sheets in only the front chamber? I'm using the 0.38 cu ft cabs - a little tight inside, and even a little stuffing in the front chamber ends up crowding the rear area of the woofer (if that matters). Also these are going to be sealed cabinets.
Any thoughts?
Thanks.
Any thoughts?
Thanks.
