I've built a number of Aleph 1.7's and this board is ok, but he uses his own part numbers making it way more work than its worth to figure out. He even has the Zetex transistors labeled with the same number on each channel leaving it a complete trace job to figure out.
He will not replay to any emails nor provide the stuffing guide he claims on his web site that he provides with the board. The guy that I bought this from also had the exact same problem. Be cautious if you buy from this guy! If anyone has used this board and has stuffing guide handy could you please IM me.
Thanks!
Mark
Thanks!
Mark
Yes, I finally got a copy this morning...if any of you need it just let me know. Probably I should post it here. Lots of issues with the KK board with holes being full of burrs and not drilled very well. I am going to have to run a drill bit through them before I stuff the board.
Mark
Mark
I am contemplating this build. Do you have the assembly manual. Would like to look at it before purchasing.
THnaks
THnaks
