The curves are presumably as measured, so you are seeing raw data basically. The small fluctuations are small, +/- 0.5dB, and possibly partly artifacts of the measurement method (high performance anechoic chambers are massive, small ones don't perform so well). I guess you could smooth the data if you wanted.
