STILL another amp
The design of the current mirror loading the second differential stage is incorrect. Also, missing resistors in each emitter of both differential stages : possibility of excessive open loop gain (HF instability, TID...) needs some corrections and tuning !
Regards, P.Lacombe
Well thnx to Nelson and P.Lacombe for their encouragements :p
I'd need to know if it's worth to corrects all the small (important) errors? Would I be better off starting with another amplifier?
I'm open to any suggestions from you audio Guru!
I thank you all for your feedback
-Simon
