I am about to stack two Amidon T130-3 iron powder cores for a high power class d amp project and i wonder if there is a simple way to calculate out number of turns required for a ~25µH inductor.
Or if i can approximate it by choosing a core of twice the size in mini ring core calculator ?
Im gonna assume its not just as simple as taking a T130-3 in mini ring core calculator and halve the amount of turns for two cores stacked, or is it ?
Theres a total of four cores that will be stacked 2 and 2 for a BTL UcD running around 150-200kHz switching frequency using four IRFP150 at 2x45V rails.
By double stacking two cores you will double the AL value.
Means with unchanged number of turns you will get double inductance.
In order to get the same inductance like with N turns on an unstacked core, you will need to reduce N by factor sqrt(2)=1.41 on the double stacked.
