Don't worry about it- any info you can give will be useful.
OK then. To begin with, I'm not a marketing guy or a salesman-- just an engineer. So I'll keep this purely technical.
The SRS SR1 audio analyzer is a dual-domain audio generator/analyzer in a stand-alone box (no external computer required). On the analog side it has a 200 kHz bandwidth, balanced and unbalanced outputs from 1uV to 28Vrms (half that for the unbalanced outputs) and input ranges from 60 mVrms to 160Vrms. On the digital side it accepts and can generate AES/SPDIF signals with sample rates between 24 kHz and 216 kHz. The digital audio is not an option, it comes with the base unit. The generator can generate all the standard digital audio test signals; sines, phased sines, IMD waveforms, squares, ramps, noise, arbs, etc. The digital generator does a few more tricks like J-Test, rotating bits, etc.
In terms of analyzers the SR1 does the traditional THD+N/wideband ampitude measurements with variable filtering, single channel FFT measurements, true dual-channel FFT measurements (where we actually ratio the input and output ffts on a shot-by shot basis so you can excite a system with noise, for instance, and still make a measurement of its phase response ), Impulse response and quasi-anechoic frequency response, THD, multitone measurements, and more. You can run two 'analyzers' at once so you can simultaneously be measuring THD+N say, and looking at the spectrum of the residual distortion signal.
SR1 also does digital audio carrier measurements including carrier amplitude and frequency and has a really slick jitter analyzer that can look at total jitter or jitter spectrum (out to 100 kHz) with a really low jitter noise floor. You can also see and transmit all the consumer/professional status bits, including user bits.
No options so far. The only significant option is what we call the "digitizer" which digitizes the digital audio carrier at 80MHz and computes jitter and produces very pretty full-color eye diagrams.
The software is similar in approach to the AP2700 software, with separate panels that control various instrument functions. Some people have commented that SR1 is "complicated", but keep in mind that the instrument is aimed towards knowledgeable audio enthusiasts, not towards keeping things simple for technicians on an assembly line. There's a complete scripting capability built in (VBscript or JScript) and the instrument can be controlled remotely via Ethernet/Serial Port/GPIB (IEEE488).
I could say things like "-110 dB distortion" but as we all know specs like distortion are complicated things that depend on frequency, amplitude, and bandwidth and you really should take a look at the detailed specs if you've gotten this far. (
Audio Analyzer - SR1 )
Base price in the US $8400. (well that's not purely technical, but it's important)
I hope that clears up some of the confusion about what the SR1 audio analyzer is and isn't.
-Andrew
