While recovering from a minor surgery I've been toying with various amp configurations in LT Spice (note - I make my living as an EE but analog amp design is not really my specialty, more of a curiosity). I have some trouble understanding the limits/envelope of square wave testing the amp especially when using difficult capacitive loads.
Let's say you have an amp with fairly deep NFB limited to a healthy 100V/us at the VAS stage and no output coil.
1. Does it make sense to test it with an input signal demanding a higher slew rate (bypassing front end HF filter)? Obviously the the input signal will generate huge error signal in the front end. Even with anti-saturation circuitry everywhere the output will not look pretty.
2. With a perfect square wave input a 100V/us slew rate amp will immediately trip over-current protection at very low output voltages (few volts or less) when presented with a capacitive load in uF range. Overriding the SOA protection in Spice is safe
but not very informative since beta of the output stage is seriously drooped at this point and it is not clear how to interpret the results.
It is obvious that a good design should recover reasonably fast and not enter continuous oscillation under these extreme conditions (since it may happen during clipping and such). However do you really expect a clean output when test fixture exceeds slew rate and/or current limit of an amp ?
