I'd like to use spraypaint to dress up the backside of some woofers for open baffle use. I just want to cover the magnets. They are the standard milled/cast steel magnet cup with a ferrite donut.
Any performance issues to worry about?
Any recommendations for primers or paint?
Thanks.
Thanks.
1) tape/cover any frame windows, you don't want paint on the cones, at all.
2) wipe what you'll paint with clean kerosene or a similar solvent, avoid gasoline/paint thinner/lighter fluid, etc. because they are both volatile and very flammable; kerosene is relatively safe and an excellent degreaser.
Wipe it dry and let it rest a couple hours so any solvent residue has a chance to evaporate.
Then paint with *good* aerosol paint, meant for metals and which is rust preventive.
Rustoleum in general has excellent paints; if you want speakers not to be very noticeable, choose satin black finish (neither bright nor flat but somewhere in between) , or check Hammerite for special effects, textured metallic .
