Welcome! There is a spl dynamics D5s amplifier.
The output stage is one of the four pop
I changed the all IR21844 . There is a PWM signal at the FET gate, but the quiescent current of 13A and rising. What could be the problem?
Thanks in advance!
Thanks in advance!
If the output FETS are not switched off fast enough or the base frequency is too high, both High and Low output will be switched on at the same time.
