Hello dear tube public,.. Can someone help me with a Service/Repair manual of a Sphinx project 4 (four) MK3 pre amplifier?
I would be very grateful
Do you have a picture of this amp (the boards)?
I maybe have some boards laying around, so i could check or reverse engineer the schematic.
These boards are not the same. Probably mine are older (much older). Anyway these are simple triode stage with a solid state buffer. The sound is a bit dull, that’s why i have the boards as the amp has been rebuild with a full tube version. I will check anyway what i can find for you.
- Tubes / Valves
- Sphinx project 4 service/repair manual
