Hello to all .
can you help me please?
it is a bit of time that I ask questions and research to identify each component
Length of the HI-FI chain that will realize for the first time.
between all the components I am delighted to be aware of 'MY-REF amplifier
because although its construction costs little, it seems that is equivalent to
products price range with four digits.
I want to find speakers that are up and that they equate to well more products
expensive as in the case of the MY-REF,
I have no trouble building them from me as it is not too difficult.
from the wall or from the floor does not matter enough that they are not very large and not too far away from the wall
room 4 x 4.5 meters
qa550 player or qa660
I2S DAC that I have not yet chosen
amp MY-REF FE
music:
Afro-funky
disco 70/80
pop
room 4 x 4.5 meters
amp MY-REF FE
music:
Afro-funky
disco 70/80
pop
You need sensitivity of 89 dB or more.
Maybe this waveguide kit: Fusion-15 Sentinel v2
-> Fusion-15 Sentinel DIY Sound Group
Woofer Eminence 15" Deltalite
Tweeter Denovo DNA-360
Sensitivity 99dB 2.83v/1m
Nominal Impedance 8 Ohm
Frequency Response 45hz - 20khz
Crossover Point 1000hz
Recommended Power 10 - 600 watts
-> Fusion-15 Sentinel build... - AVS Forum | Home Theater Discussions And Reviews
Others waveguide kits:
-> http://www.diysoundgroup.com/waveguide-speaker-kits.html
Transmission Line kits
88 - 89 dB
IPL ACOUSTICS HIGH QUALITY SPEAKER KITS
-> IPL ACOUSTICS**** TRANSMISSION LINE KITS
DIY IPL Acoustics Transmission Line S4tl Speaker Kit Build
88 - 89 dB
For 50W of maximum output I recommend 92dB to 98dB speakers.
I use 88dB speakers and the 60W chip amplifier is incapable of vigorous music levels. Great for background, or listening to "ordinary" program material, but it can't be turned up much, without becoming strained and that "Too Loud" effect due to excessive clipping of transients.
Bass-reflex (rear)
91 dB
Plutone, by Tony Gee
-> Humble Homemade Hifi - Plutone
91 dB
I wrote in other thread:
With the same woofer Jantzen Audio HMQ JA-8008, by Troels Gravesen:
-> QUATTRO-mkII
-> JA8008-HMQ
If we compare the Plutone of Tony Gee ... we appreciate much more their new kit, a wonder what he has achieved, for lack of hearing. And they say, less is more. I take off my hat.
And without resitors.
-> QUATTRO-mkII
-> JA8008-HMQ
Volt-10 LX DIY Sound Group
Quick review of the Volt 10 - AVS Forum | Home Theater Discussions And Reviews
Fusion-8 DIY Sound Group
DIY Sound Group Fusion-8 Alchemy build
-> DIY Sound Group Fusion-8 Alchemy build
You need one or two subwoofers.
not to know .
I entrust myself to you
...from the wall or from the floor does not matter enough that they are not very large and not too far away from the wall
room 4 x 4.5 meters
amp MY-REF FE
music:
Afro-funky
disco 70/80
pop
Pro-Audio and lighting Calculators. Calculator page
Sound meter in Android: https://play.google.com/store/search?q=sound%20meter&c=apps&hl=en
IPL S3TL Mk3 TRANSMISSIONLINE
You do not listen orchestral music, with high dynamic range (DR: 12... 17). 94 dB peak is very high to others musics, usually with DR < 10.Impedance ohms...............8
Dimensions mm............... 903mm (inc.spikes) x230W x310D
Line Type........................ triple-folded
Cabinet material...............18 mm MDF (grille 9mm)
Crossover khz......3.khz , 2nd order
Suggested int. wiring .....HU1 silver PTFE (5m reqd)
Sensitivity db SPL....89
Suggested min room size ..14 x 12ft or equiv. [maty: 4.2m x 3.6m]
Frequency Response....27htz - 30khz
Frequency Linearity...+ or - 1.5db (250 to 20khz)
http://www.humblehomemadehifi.com/Plutone/Plutone_SPL_off-axis.jpg
Above: On-axis and off-axis frequency measurements show very even response curves. This indicates a constant and neutral tonal balance under any angle and therefore the size of the sound-stage can be tuned to personal taste and room acoustics without altering the tonal balance of the loudspeakers. Red on-axis; Green 15 degrees off-axis; Purple 30 degrees off-axis; Yellow 45 degrees off-axis; Range 200Hz - 20kHz / Vertical scale 50-100dB; subdivisions 2dB's
- speakers for MY-REF FE
