First of all, I listen to a whole lot of electronica with a lot of material in the lower octaves.
I would love to stick with a 2 way setup, but everything I have tried to model thus far doesn't seem like it will work very well. i.e. woofers needing to be lowpassed at 800-1200hz vs tweeters needing to be high passed at 1.5-2khz. A substantial gap. I realize I am not going to get an F3 of 30hz in a 2 way sealed cabinet like I want so 50-55hz might be more reasonable. I am hesitant to go ported now because the music i listen to is relatively fast and these will likely be delegated to a surround sound role when I have the opportunity to build or buy what I want for my mains.
One thing I have considered is adding a 1-3 ohm resistor in series with the voice coil of the midwoofer to raise QES and shift the F3 down 10-20hz. I know this will kill the efficiency, and increase box volume, but I should have plenty of power. What are the other effects this might have on the sound ?
I would like to keep each channel all in one cabinet no taller than about 4 feet high and 12-15" square on the bottom. Going to a 3 way design, or even an MTM will likely push me over budget. I might consider a pair of bookshelf's and a separate sub, but then money and power start to become the determining factors.
I have 120 watts x 2 into 8 ohms, and around 190x2 into 4 ohms (until i can upgrade the transformer) to work with now, and I will probably build another amp with some the national semiconductor overture series IC's for 40 or 50 more watts per channel available for biamping.
Any ideas or designs you have had success with given my parameters?
Thanks a lot
jt
Thanks a lot
jt
