I thought I'd get some opinions/thoughts from the experts. I've been planning to build a set of speakers for some time, but need a little help on the design end of things. I'm hoping to roll with this project in near future, though it will take some time to do.
What I plan to do is use a pair of 168E Sigmas running full-range but rolling off the bottom end, say around 200-250hz or so with a simple cap. Then, bringing in a 12" woofer on the bottom on each side. Right now, I'm thinking one of the better Eminence pro sound drivers. Basically, I'll have two cabinets on each side, with the 168 cab sitting on top of the woofer cab, possibly spiked to it. I may incorporate a supertweeter for just a that last touch of air, as I have a pair not in use.
My main question is, how to house the 168E Sigmas? Should I do something sealed? A small folded pipe? Ported? Any thoughts would be appreciated. And if you have any specifics as to the enclosure size, that would be appreciated. My main goal is to make sure the sound is nice, tight, and full bodied.
Then there are the woofer cabs. My intial thought is just to do a ported cab. But is that the best option here? I'm thinking of the Eminence Magnums, which will work in a smaller cab than most. Again, could try a folded pipe, MLTL, etc. I'll have some size to work with, but can't go huge.
One more question, how to amplify the system? I have been using 300Bs, but have recently aquired and interesting gainclone in the form of an Audio Zone 40 watt prototype. It's really quite a nice amp, (very smooth, wonderful imaging, full sound) but is that enough juice for both drivers? Or should I use a plate amp for the subs? The 12" drivers look to be about 95db and the Fostex is 94.5 (as I recall).
Any thoughts would be greatly appreciated! Cheers!
