Greetings!
I'd like to do some experimentation with a small (sub)woofer box. I've been looking around for a suitable program to do the calculations, and I ended up with the "bass" program (by K. Foellner) which does a quite fine job.
The shortcoming of this (and many other) programs is that it allows only one driver. Is there any program that can deal with 2 or 3 (identical) drivers ???
Herman
Herman
There are two programs that are pretty easy to use. One is <a href="http://www.danbbs.dk/~ko/ubmodel.htm">UNIBOX</a> and the other is <a href="http://www.linearteam.dk/">WinISD</a>. You need to have the Thiell/Small parameters for the specifici driver to use these programs. They are usually available from the manufacturer/retailer of the driver. If you can't find the T/S for some particular driver, then move on and find another driver.
You could also try LSPCad.
This app lets you model sealed, vented, isobaric, bandpass .....
I've been trying out 'LSPCad Lite' and its easy to use. Its up to version 4 now and you can get a demo version from http://www.ijdata.com
Good luck,
Simon
Good luck,
Simon
