Below are two scope shots of SPDIF output from the same device - the only difference between them is a better PS.
The better PS speeds up the rise/fall slope of the SPDIF waveform. About half way up the slope of the line is the decision point. I believe that the faster/steeper slope makes for a more accurate decision point with a better chance of it matching the timing of the decision point of the ADC recording & less variability between decision points. Any anomalies in this timing leads to jitter.
The one with the better PS also sounds better
USB power
Better PS
The first pic shows a kink on the slope, I believe - could this be the result of a reflection falling on & superimposing on the slope?
The ringing on the top of the waveform also seems to be tamed somewhat in the bottom pic.
What sort of explanation can be used to explain the speed up & this sort of change in the waveform based solely on better power - lower impedance, less noise?
USB power
Better PS
