Sparks flying in Parasound
I know this is odd, but never the less true!
In my Parasound HCA 2200 MK II sparks fly when turned on.
Front facing you, it seems to come from the upper right boards backside. Dismantled nothing on board, nothing to see, vacuumed still same thing.
Nothing in the sound, nothing in the speakers.
It's provoked slightly more when warm, shut off for a min to change cables, and then back on. Then I simply pray to the hifigod, not to leave it in flames.
HELP!
View attachment HCA2200II.pdf
By the way if you know this construction, you know the sound - and the sound compared to others.
When I compare it to my DOXA 73 signature, a not too powerfull 70W highend poweramp or other amps for that matter. The Parasound sounds compressed, but even worse, it seems to have a phase reversal in the midtone or crossover fuckup somehow. When the powerplug is reversed in the socket, it sounds even worse, kinda the other way around.
What can that be?
