Hello all!
I finaly set up my system but last thing I need to do is "add an element of volume adjustment" in my bi-amping.
it looks like this:
bluray doing for transport and it is connected to the 2 systems.
Through the HDMI to the av receiver -> TV and from receiver to small bookshelfs- thats 1 system and its also connected (bluray) parallel through digital out (coax) to beringher DCX2496 crossover of which I use as well as DAC, and from DCX analog signal goes to 2 amps.
one amp is tube amp yaqin 100b KT88 and it powers fullrange drivers : TangBand W8 1808
the other amp is class d power amp which powers basses.
If I dnot care that much for quality all the work is done by cheap AV receiver and small bookshelf but if I want to switch to other system trouble starts,
its the same BlurayP-> Digit (caox) -> DCX -> (analog) 2xAMP
the problem I am havving is with setting volumes, all works fine but its a bit problematic as it needs to be done independently and not having remote control for volume its really quite tedious and anoying so I thought thats what I would like to implement.
Ideally would like to insert some "audio interface" which could take coax digital in and output same signal with the possibility of Volume adjustment with remote control. I could then set both amplifiers to my max listenable volume level and control volume setting just with this remote control if there is any gadget on the market which would do that i could actually place that thing in my signal path between bluray and DCX2496.
Other solution that comes to my mind is to replace the current bluray with other transport which got build itself the ability to adjust the volume control on this dig out (coax).
I thought also about some multimedia player and replacing my current bluray but again it has to got a volume adjuster&remote control and be also able to read bluray discs.
any suggestions?
ps. sorry for my english🙂
it looks like this:
any suggestions?
