I have a USA-100 that only has audio on one channel. I opened up the amp and found a resistor that is black. Dose anyone know the value and wattage of the resistor? Also any other info on the amp not having output on a channel.
The switches are the likely cause for the dead channel.
The resistor is likely 10 ohms if it connects between the primary and secondary grounds but I don't have anything on this amp specifically.
Where would I be able to find a replacement switch? Dose anyone know what the wattage of the resistor would be? It looks large.
Measure it with dial calipers and order the same size. The resistor generally has 0v across it. The size is to prevent it from failing immediately when the RCAs are shorted to 12v or a speaker wire is shorted to ground (which typically causes other problems as well). Various diagrams have similar resistors as 1w.
Maybe someone knows him. I don't but an ebay seller named Jaime (JandRElectronics, maybe J&RElectronics) used to sell them. Id try cleaning them with contact cleaner (DeOxIt D5 or similar) before replacing them. Did you find one was intermittent?.
I found that I was not getting a contact closure when the switch is going to stereo. Do I have to un solder the switch and open it to clean it or just spray in while it was installed?
Initially, apply a drop or two of contact cleaner and work the switch back and forth 40-50 times. If it seems OK, move the switch actuator slightly while it's playing to see if it's intermittent. Some of the SoundStream switches have sliding contacts and clean pretty well. Others work like a toggle switch (even those with a slide-type mechanism) and have to be disassembled to be cleaned (tedious and risky due to the risk of losing small parts).
So I measured the resistor and i get 0.145in x 0.445in. Am I looking for something in the case code section? Also I dont see anything with the tan coloring of the resistor, dose that matter?
You're looking for something that's the same size.
The color is not important but the tan color is likely paint and less desirable. You should use something that's less likely to burn when it fails. Metal oxide or metal oxide film are generally ceramic coated and generally flameproof.
- General Interest
- Car Audio
- Soundstream USA-100
