Hi all,
Recently purchased a faulty Japanese Soulnote DC-1.0 DAC with buzzing/motorboating on both outputs. Balanced PCM1792 D/A conversion with SE and Bal outputs and a memory clocking feature using a memory buffer which works in conjunction with a Altera Cyclone EP1C3T144C8N FPGA.
Appararently the problem developed not long ago. Based off quick physical inspection, no burnt spots, voltages to output and from the separate analogue and digital supplies measure fine. Has 2 x quad amber leds for the I/V stage/output to give indication power supply is present in the the pair of outputs.
There is a hex inverter near the 16.9mhz clock that looks to have been replaced. 74LV04A is the part and the original LVD04A (could not locate a datasheet) is also supplied (although evidently desoldered).
The spdif input locks onto a 44.1khz redbook standard and will not lock on any signals above (48khz etc). I've read some translated blurbs that the DAC is mainly targetted for the CD transport market.
Some internals and Japanese snippets of information on the DAC:
http://www.yoshidaen.com/dc1.html
Apparently these hex inverters are electrically sensitive and fragile. Now the question is could this damaged part be the cause for motorboating issue on output? It would be hard to identify the I/V discrete stage or the dual PCM1792 as the problem as problem is on the outputs and happens simultaneously.
Example video of problem (not mine) but I get same problem.
YouTube
Pictures:
cbt gif
YouTube
Pictures:
cbt gif
