Does any one have the Sony TA-F808ES amp?
I am seriously thinking of buying one on ebay, the user reviews I have read so far look good. It seems to be built like a tank and should last a while. Any Mods???
How much should I pay???? In Euros or £s.
I have Proac Response 1SC speakers and think this would have the weight and authority to drive them. Here are the specs from Proacs website
http://www.proac-loudspeakers.com/1sc.php
Nominal Impedance - 8 ohms
Recommended Amplifiers -20 to 100 watts
Frequency Response - 38hz to 30Khz
Sensitivity - 86db linear for 1 watt at 1 metre
Bass/Midrange -New five inch unit with special transparent cone. Copper magnet assembly and
phase plug mounted on die-cast chassis. High temperature voice coil.
Tweeter -ProAc three quarter inch dome unit, with honeycomb - wound voice coil.
Special damping and ferrofluid-cooled coil assembly.
Crossover Finest components on dedicated circuit board. Multistrand oxygen-free copper cable throughout. Split for optional bi-wiring and bi-amping.
Dimensions
12" (305mm) high
7" (178mm) wide
9 1/4" (235mm) deep
Weight
18lbs (8kg)/cabinet
Lee
Dimensions
12" (305mm) high
7" (178mm) wide
9 1/4" (235mm) deep
Weight
18lbs (8kg)/cabinet
Lee
Well I have bought one on ebay and am awaiting it from Germany. It cost me £430 with delivery, is that too much or a good purchase do you think.
It will be interesting to see how it compares against my 100w AVI.
Well this is embarrassing the length of time before replying.
The Sony drives the proacs with real authority, it's just effortless. Very clean not harsh at all. I suppose so much of it is down to the size of the psu , caps, construction and circuit. A really super spleaper amp bargain .
Nice!
hifiengine.com has the service manual for your amp:
Sony TA-F808ES Manual - Stereo Integrated Amplifier - HiFi Engine
Peter
Peter
