Sony Kit
I don't think you can get more output from a Sony unit without replacing the entire amplifier and power supply section. The amp designs are pretty much maxed out, and the transformers are usually underrated... maybe you could upgrade that. Make sure your on 8-ohm mode if u have a switch as the output is halfed in 4-ohm mode.
