I’ll eventually set mine up again…my life is in upheaval due to a move to a new house.
There is more room, so more room for systems.
I enjoy them too much to let go…a revised baffle is in progress so I can easily swap between different drivers and not let go of anything 😉
Look at the SP.
Measured in square metres (m2). The effective projected area of the cone or diaphragm. It is difficult to measure and depends largely on the shape and properties of the surround. Generally accepted as the cone body diameter plus one third to one half the width of the annulus (surround). Drivers with wide roll surrounds can have significantly less
than conventional types with the same frame diameter.
