First of all hello, I'm new here.
I'd like to submit a question
I managed to buy a T-Amp(the T-Amp is hard to find here in Italy, so I managed to have one from abroad,but it has not been easy!), I bought a stabilised power adaptor, 12 V, 3.5 A, to use it at home.
For the moment I found two loudspeakers of an old stereo I had, they have 4 wires each (grey, blue, ref, black) which were connected 2 by 2. I was suggested to use them this way, so I just connected them to the T-Amp, 2 wires for the red pin, 2 wires for the black, for both channels. I tried and it worked but after a couple of minutes it stopped. The T-Amp is still turned on with the red light on but no sound coming.
I checked the loudspeakers and I saw the couples of wires were for high (8 ohm) and low (2.7 ohm) impedance and the way they were connected was in parallel, so probably I used the T-Amp with 2.7 ohm impedance !! and now it's gone!!!
I'm wondering if this means that the tripath chip and all are gone, so I can throw it away, or could it be that by replacing some component I can repair it (it still turns on)? If yes, which?
Thank you for your help
