Son of Dork: General
The Son of Dork (SOD) project is the result of the diyAudio.com multi-channel preamp initiative (http://www.diyaudio.com/forums/showthread.php?threadid=3517). The project has been split into threads dedicated to discussion of the preamp's different functional units:
- General Discussion (project status, functional requirements)
- Active Circuitry
- Attenuator
- Power Supply
- Connections and Layout (including input switching)
- Chassis and Construction
- Hardware Logic, Controls, Display
- Microprocessor (programming, implementation)
I will be managing the project as a whole, as well as initially overseeing individual threads. For a background on the project, please see the original thread referenced above. A website dedicated to the project will be located at http://dorkus.org/diy/sod.
Let the fun begin!
requirements
here are some basic requirements inherited from the original thread.
- solid state line stage, no phono
- traditional AC power supply
- DC or AC coupled
- optional balanced outputs/inputs (to be decided based on gain stage topology)
- minimum 10V RMS unbalanced output drive capability w/low distortion into 10k load; 4V RMS into 600 ohm load
- stability into capacitive loads
- HF response at least -3dB @100kHz
- possibly implemented with SMT devices
- each channel will be a separate module
- digitally-controlled attenuator with at least 1dB resolution over a 70dB range
- microprocessor-based controller in separate chassis, full remote control
there were many other peripheral requirements that came up but i can't recall them at the moment, the last thread got much too long. but this is a basic starting point.
please be sure to keep these requirements in mind before you post a thought. i've had to respond to way too many questions that could have been avoided if people had read the requirements more carefully.
cheers,
marc
