Picked up an amp that I knew had some issues but they should have been minor. (Cosmetic/connection related)
Both channels play, one is just a bit quiet compared to the other side but they can be matched, and when the crossover is in fullpass or high pass, I can hear some component "playing" the input. Sort of a high pitched buzz but can actually make out words (DJ on between songs)
I've wiggled/touched different parts but can't isolate it. It does raise in intensity with the amps bass/treble controls and to some extent with the channel gains. Crossover in low pass I can't hear it but I haven't fed it some bass heavy music and turned it up to duplicate it.
~1996-97ish? Fosgate 200x2
Any suggestions would be appreciated!
