I just purchased an adjustable heat soldering station and wondered what heat I should use when doing cap replacement etc. on circuit boards. I've had trouble in the past with the cheap irons that I bought from Radio Shack on the thin PCB's in Sony and Philips DVD players lifting and vaporizing traces. Part of it was my inept solderng skills but the iron was a problem too.
The soldering station has a working temperature of 392-896 deg F. Recommendations?
Thank you!
Jim
Thank you!
Jim
Hugo,
Thank you for your response. I'll give it a try.
Jim
Jim
Netlist said:Something like 400°C and a clean soldering tip can do wonders.
Oops, I see you are talking °F and thought you couldn't go lower then 392°C. Now, 392°F = 200°C so try something like 570°F to start with.
/Hugo![]()
When i replace elkos
i first pull the case from the pcb
just push the case sideways this will disconnect the pins from the alu.foil
Nou you can easally desolder the remaining pins wich are much more easy to heat up.
This will work with the normal coaxial versions. But not the really large ones.
Simon
Simon
