Soldering Inside A Cabinet
This has to be one of the most frustrating things in diyaudio. Not much lead, have to take the solder wand in. I strip both wires, twist, and somewhat secure with alligator clips. Both hands tied up, one with solder pencil, the other with solder. Is there a better way?
You can buy tape solder. If you cannot buy tape solder, take a piece of regular multicore wire solder, put it on a flat, hard surface and squash it into tape by rolling a piece of round steel bar up and down it a few times. You have to lean hard on the bar. If you haven't got a suitable piece of steel you can probably use a glass bottle.
Twist the wires to be soldered together, having first slipped a piece of shrink-wrap tubing onto one side. Wrap the joint with solder tape and apply a tinned, clean soldering iron as normal. When the joint is made, slide the shrink-wrap over it and heat with a heat-gun or gas cigarette lighter if space is limited.
Job done.
w
A bit of tape solder is a useful thing to carry in your wallet. You can make a joint without a soldering iron, as long as you have a match or cigarette lighter.
Job done.
w
Neat tip, never heard of this stuff before, will add it to my ever growing arsenal of repair tricks. Thanks.
