The 6L6 is used in the power supply as a feed forward shunt regulator.
Interesting, thanks. I wondered if the 6L6 was used that way. And this has no driver circuit, so you must have a preamp that provides adequate signal? I'll try to have a read through the link you provided.
Edit: Or perhaps not if this is a preamp, though I've never thought a 6V6 with it's swing requirements would serve as a driver per se. I'll have to read that thread as I'd think you'd need quite a big signal coming into this amp to make it work well. But maybe there's something I don't know going on here.
Edit 2: OK, read it. While the 6V6 wants more swing to take full advantage (particularly as an output tube), this amp utilizes just standard 1-2v output of lots of sources. Pretty constrained on the plate curves. I've never done this so am curious how it sounds.
Anyway, the amp looks quite nice!
Carl
