Ok, here's the story. I have two pairs of speakers in my home right now. One is a pair of Snell Ds, the other a pair of Snell C/Vs. The C/V betters the D in a number of areas. The low end is vastly superior, with more weight, extension and control. The midrange is absolutely neutral. And the C/V will play at much higher levels without strain.
Both models use the exact same drivers. The D is a 3 way, with a 1" inch Audax titanium dome tweeter, a 5" midrange, an 8" woofer, and a rear firing tweeter in a 43 inch tall tower. The C/V adds an additional midrange with the tweeter sandwiched in an MTM array, and an additional 8" woofer in a 47 inch tall tower. Here are links for each model:
http://www.snellacoustics.com/typeCV.htm
http://www.snellacoustics.com/typeD.htm
There are two areas in which the D betters the C/V. There is more air at the top end, with more sheen on cymbals. And the sound stage seems to be deeper with the D, which may very well be related to the better HF output of the D that I just mentioned. As I previously mentioned, both speakers use identical drivers, in very similar cabinets. With that in mind, the only reason I can think of for the lack of air in the C/V would be the crossover. But I have also been told that an MTM array drastically affects (reduces) off-axis HF response. Are there crossover mods that I could make to address this issue, or does an MTM array, by nature, account for the difference I am hearing? After listening to the D it is clear that this tweeter is capable of sounding quite good.
Thanks for any help!
