hi
i have problem with this device...
whats its name?
http://upload7.ir/images/33781328495762106022.jpg
this device use in this circut...a 1kw(100v,10A) smps.
another question is:can i use IGBT against MOSfet?
http://upload7.ir/images/94042656889167702535.jpg
whats its name?
It is an optocoupler.
Used to isolate the primary from the secondard windings voltages of the output transformer.
Used so ensure the high output voltages don't destroy the low voltage packages on the left of the circuit.
hi
Yes you can.
Are you sure you know what you are doing?
Yes you can.
i'm in a doubt!!!
