Hi All:
Have been lurking on this site for some time, but this is my first post. Could use some help on a possible home theater design using full rangers.
I am in the process of a home remodel. I would like to convert a medium sized room (approximately 15 x 15 feet) into a home theater. I am contemplating some DIY full range drivers in boxes designed to fit between wall studs.
I'd like to use either Fostex FE83en or Alpair 5, both of which are 3-inch drivers. Here are my questions:
1. Will either of these drivers work? Or are they too small?
2. Will off-axis performance of single drivers be an issue since each speaker will be flush with the walls and can't be towed in like regular box speakers?
3. I assume the boxes have to be sealed since they will be covered by drywall, except for the driver of course. Will these drivers work in a sealed box? If so, how do you determine the volume? I have not seen any sealed box options after searching online.
I will be using a sub. So the the lack of bass from the fronts and surrounds is not an issue I believe.
Appreciate any feedback or guidance from the experts on this forum can offer.
Thanks.
Jim
Thanks.
Jim
