I've just applied DeoxIT on a few switches that weren't working well, and, while it cleans the contacts very well, it makes the mechanical action work quite poorly as it seems to remove any oil or grease that was there.
I bought D5 and G5 in spray cans only, not in every single formats available as it's quite expensive.
when I've cleaned switches I like to use a pretty liberal amount of aerosol deox (brand/type of choice) with some modification of a vacuum cleaner nozzle tucked behind the switch as I spray in order to remove what's getting flushed out. The flushings from switches are going to be particle laden and conductive. Exactly why you don't want them inside in the first place, and also why you don't want them near anything else on your circuit.
Seems like pure silicone would be the best replacement for lubricity. It'll be interesting to see what others here say. I found that many available "100percent" silicone aerosols have pretty harsh ingredients, including acetone! Oddly enough the labels say safe for all plastics. I use a USDA food-grade brand without any of these.
Would this work?
http://www.asalco.com/pdf/FOODGRADESILICONE_en.pdf
By the way, I have a contact cleaner ( http://www.asalco.com/pdf/CONTACT 2000_en.pdf ) which is pretty good at removing the dried residue the DeoxIT leaves, the only problem is that when I spray it, contacts stop working well...
Should I clean things up well with it and re-spray DeoxIT afterwards?
Don't do this with flammable cleaners - if the vapour gets near the motor brushgear...
bluebeard said:... I found that many available "100percent" silicone aerosols have pretty harsh ingredients, including acetone! ...
I don't know what you mean by "harsh" but acetone is actually pretty benign stuff. It is a great solvent for some applications, produced by bacteria, just like ethanol, or synthesized from isopropyl alcohol. If water won't dissolve a particular "target", try acetone. Water works for negatively charged ions, acetone for positively charged ions.
I_F
Hi all,
thanks!
It turns out I bought FaderLube as well. What should be the cleaning method then?
*The D5 dissolves lots of particles, but they all dry out after a few minutes. Should I then use alcohol and/or acetone to remove most of the flushed residue?
*Following the cleanup, do I reapply D5 in case the cleaning products caused oxydation on the contacts? (When using isopropyl alcohol, for example -> contains water)
*Then should I apply ProGold or FaderLube depending on the contacts, or both? Reasons :
thanks!
- When I cleaned the contacts in my amp, the source selector only started working after I applied ProGold, D5 didn't improve things much. If I only use FaderLube, will it work well?
- FaderLube is made for conductive plastics, does it mean it's conductive or only that it contains lubrificant?
- General Interest
- Everything Else
- Slide/push switches and DeoxIT
