Hi All,
Anybody try Skaaning Flexunits 4H vs the C-Quenze 18H woofer and can tell me what sound better in stereo application?
The Flexunits 4H use in Sonus Faber Guarneri and the C-Quenze 18H use in Peak-Consult InCognito.
Thank you very much.
http://www.audiotechnology.dk/iz.asp?id=4|a|122|||
http://www.audiotechnology.dk/iz.asp?id=4|a|135|||
Bill Fitzpatrick said:Links don't work for me.
Select: Flex units -> 4"
Select: C-Quenze -> 18 cm
I'm using the C-Quenze 15cm units (wound to 4Ohm and with the biggest magnet they do). Completely wron application for your question because I'm using them in a car! but I will say they have the most fluid and realistic midrange I've head this side of ATC 3" dome mids. From what I've been told the C-Quenze do have a finer midrange at slight expense of the midbass performance, out of those two I'd personally go for the larger C-Quenze unit.
Maybe you can tell us what your application actually is. Mid-woofer in a small two-way, low-mid in a large three-way etc ... ?
Charles
Charles
phase_accurate said:Maybe you can tell us what your application actually is. Mid-woofer in a small two-way, low-mid in a large three-way etc ... ?
Charles
My design is for 2 way application, similar to Sunus Faber and Peak-Consult.
Thank you very much 🙂
Are there any kits out there using Flexunits or C-quenze as a two way monitor? I plan on building one with two passive radiators. I've put the design on the web here:
http://users.telenet.be/hexateq/
Richard
Richard
richardkrol said:Are there any kits out there using Flexunits or C-quenze as a two way monitor? I plan on building one with two passive radiators. I've put the design on the web here:
Richard
The dutch company www.deaudiofabriek.nl is working on some kits. At the moment there is a small monitor consisting the 15H and Raidho tweeter. A 2,5-way floorstanding speaker is on its way.
- Skaaning (AudioTechnology) woofers
