Hi!
I'm contemplating building a speaker with a 12" or 15" - a bit like a Tannoy Arden if you will - and am wondering about the ports: If I have front-facing ports, will there be a risk of hearing higher frequencies from the ports as "ghost" tones? The crossover frequency would probably be somewhere around 1500-1800Hz.
Cheers
Es
Cheers
Es
Put the ports on the bottom and the enclosure on small legs.
Do NOT build the enclosure like an Arden; it's an unbraced resonant piece of ****.I'm contemplating building a speaker with a 12" or 15" - a bit like a Tannoy Arden if you will
I do realize that - hence the "bit". Please read "a bit like a heavily braced Tannoy Arden"
