size does matter
This is some info about a loudspeaker my father built in the 60's to match his DIY tube amp (24W with 2 6L6G output tubes):
One case 700L (around 110cm wide, 80cm high, 80cm deep) which contained:
a closed midtone case with one midrange driver.
a closed high-tone case with four metal-film drives in a concave setup.
a 10" bass-driver.
All casing was 30mm chipboard, glued and screwed together.
A separate second midtone-case provided 'pseudo stereo'.
All-in-all the total system performed awesome...
And then real stereo arrived and there wasn't enough room (and bucks I think) to complete another amp + case.
The loudspeaker has been scrapped. Photo's are found in my baby-album.
The amp is still around (and working from time to time)...
Size does matter...
I wonder, does anyone make diy speakers of this size nowadays??
Jos
[Edited by dutch diy on 07-13-2001 at 05:34 PM]
a 10" bass-driver.
Size does matter...
Jos
