In this year build some amps prototypes and sound good ..only good. (doz ..esp.. gainclones rotels..arcams..fets..naims..Hk…Dx..regas…albarry...and much more)but have an question…when exchange some components in the main fiberglass of the my protoamps the sound exchange too….but the question is :
How sound the same prototypes in half size fiberglass board?...more…more small size.
This affects the amp sound?
If I understand you correct, you ask if the sound will be affected if you make the prototype board smaller ?
If so, it could affect the sound both ways;
In a good way because the signal path gets shorter....
In a bad way because you may have high power tracks very close to small signal tracks...
Always think when making layouts 😉
tadium: " How [is the] sound [changed by] the same prototypes [on smaller] half size fiberglass board?"
ACD: " If so, it could affect the sound both ways;
" In a good way because the signal path gets shorter....
" In a bad way because you may have high power tracks very close to small signal tracks... "
Pardon my re-interpretation of your original question(s).
I agree with ACD, as signal pathways change in length and / or size the sound reproduced will often be somewhat different. Also the board material, if different, can have a dramatic effect on the sound, mostly because of the different capacitance (different dielectric material) between signal paths on the board. ACD is also correct: reducing the physical size of a circuit board will certainly bring the signal traces closer to the power traces, adding to the crosstalk and impedance changes.
Sometimes there is magic in the way a certain project was designed and scaling it down or up can dramatically change the end results. 😱
(I really like ADC's ultra flat power MOSFET amp board pictured on his web site ... 😀 )
ACD: Your flat amp board ... do you have an equally flat power supply filter board ... I am building amps in "one up" rack mount chassis and those tall capacitors present a problem (even when using switching supplies). 😕
thanks
and the winner is....? small board... medium board o big size board?
maybe wire point to point the components type old valve style?
Winner for size selection?
IMHO chose the trace size to suit your amp power (pre-amp = smaller, power amp larger, big power amp quite large), then generally accepted good practice dictate the resulting board size required. For a good example see the 150 Watt board that ACD builds at his web site = that "flat" amp board ... 😉 ... note the "fat" traces where the power is routed, the slim traces back in the low power section(s) ... I estimate that board to be about 3" by 7" ...
CBS240 said:
I GUESS YOU'R STILL YOUNG ENOUGH TO SEE THEM
- Size dilemma question?
