Hi everyone,
I'm building a psu from a toroïd: +12V/0V/-12V AC 160VA. (2x 6.66A)
Nothing high end for now, because everything that comes behind it, is simple at the moment.
However the supply should be very good so that I can use it in further projects. Besides, if the psu doesn't work good, everything next will never be good, right?!
Something that I can't seem to find out is, why should I use two bridge rectifiers if one can do it equally well and even have about 1.2V more output and have less components. (one vs. two bridges)
Or shouldn't I ...?
What is the better choice and please include 'why' it is so.
Thank you!
Bart
Or shouldn't I ...?
Thank you!
Bart
Thanks for your answer AndrewT, but...
This toroïd has dual secondaries. (four wires)
So, should I connect the end of the first with the beginning of the second to have a center and use one bridge?
Or use two bridges at each secondary?
Bart
edit: I see now how my initial post is confusing, sorry.
Bart
in a mono (single channel) amplifier, I have found no difference in noise and/or hum with the single rectifier off the centre tapped compared to the dual rectifier off the dual secondary.
However, when building a two (or more) channel amplifier, some builders find that it is easier to get a quieter output by adopting the dual rectifier topology.
ßart West-VL. said:why should I use two bridge rectifiers
This is my understanding of the situation:
If your circuit draws no current then one bridge is ok.
But if you are drawing current from the transformer then you have a volt drop across the transformer windings.
With an AC music signal - lets say 500hz - you draw current alternately from each transformer winding, another alternation also happens when the 50hz AC power switches polarity.
These two circumstances that cause alternate current draw between the two transformer secondary windings means that the volt drop in the transformer is transferred alternately and somewhat randomly ( depending on the mixture of AC 50 or 60 Hz and whatever frequencies the signal is creating ) between the coils. Because the two halves of the transformer secondary are joined together AND connected to earth this transference of volt drop pulls the earth around and this is effectively injecting a spurious signal into the earth line.
If you have 2 bridges, the two halves of the transformer are independent from each other and the star earth point is established AFTER the bridges. So now, the two coils can move independently of each other according to what ever the current demand & corresponding voltage drop is and, because the earth is not connected here, this switching transient is not generated
That is the complicated answer & I hope I have explained it clearly enough for you to see it.
The simple answer is that it sounds better ..
The reason isn't that compicated and doesn't need any assymetry or randomness or equally strange concepts. The reason is: High current pulses flow between the caps and transformer.
Which is why you should never take the transformer center tap to a "star" ground. It should go directly to the caps. One wire connects the point where caps and center tap meet to the star ground. If the center tap is connected to the star ground you'll get problems as the high current charging pulses will create a voltage drop over anything they flow through. Like the star ground bolt if you are using one. This will easily cause hum in amps with more than one channel.
Do you mean safety earth? If it is connected to signal ground you can have problems when interconnecting different pieces of equipment. Then again, if you don't you will have a safety hazard if you use a transformer without reinforced insulation or a grounded shield. With balanced interconnections this problem does not exist.
you miss my point
the mains safety earth can be connected but that is not the what we are discussing.
with a dual bridge the point is that the main "power earth" is not connected to the secondaries......
it is connected after the diodes.
the two secondaries are then left to float separately.
Okay, I see what you mean. But why does this matter? I can see that with the dual bridges mains borne noise will have a harder time getting into the amplifier - as long as the bridges don't conduct. This means mains borne noise is gated at 100Hz into the amplifier, is this really better? I'd rather build the amplifier to not care about it. The big filter electrolytics will swallow the differential mode noise, and if the output of the PS is connected to chassis the common mode noise won't trouble the ampifier either.
To me the center tapped connection seems like a better idea: When using two bridges each rail can only support half the output power of the supply. If using a single bridge and center tap then the supply can support almost as much power (but with more ripple) from one rail as it can when both are loaded equally. It might not matter much but it might sag less on low bass signals.
megajocke said:Which is why you should never take the transformer center tap to a "star" ground. It should go directly to the caps. One wire connects the point where caps and center tap meet to the star ground. If the center tap is connected to the star ground you'll get problems as the high current charging pulses will create a voltage drop over anything they flow through. Like the star ground bolt if you are using one. This will easily cause hum in amps with more than one channel.
Greetings, All this is understood and I agree. My question is, What about the speaker return? Should this also go to the center of the caps or back to the star ground? Sort of like a closed loop from the power supply caps to the amps and return back to the power supply caps.
Seems to me it should go to the star ground where no high currents are creating noise and ground loops but I wanted to ask the experts.
Regards, Marcus
Thank you very much,
So far it seems that it is quite complicated and depends on what I want to use it for and what gets attached to the PSU, how it will be grounded, etc.
I must say at this point, for clarity reasons, that my plan was to open a thread specifically about creating a power supply unit with passive components only, that everyone could refer to if there where new people introduced in the diy audio world.
I had no luck contacting 'diyaudio' yet.
If someone could point me to the right E-mail please?
"webmaster @ diyaudio . com" doesn't seem to reply to such questions.
That being said...
I would gladly post pictures and drawings, simulations, etc. while going true "the making of..." after I receive info from this forum's administrator, so that I don't mess it up before I even start.
About the single vs. dual bridge; still not sure what the pro's and con's are at this point. And more importantly, what weighs down more.
I did learn a few things already, thanks a lot!
Bart
That being said...
Bart
there is already a permanent Power Supplies thread.AndrewT said:in a mono (single channel) amplifier, I have found no difference in noise and/or hum with the single rectifier off the centre tapped compared to the dual rectifier off the dual secondary.
I know, I started this thread in it.AndrewT said:there is already a permanent Power Supplies thread.
So you think I can just start a tutorial-thread and it will be OK?
I have seen strange reasons one some occasions, to flame a poster for what he/she does, that's why I wanted to ask someone if it's OK to do such a thing on the forum.
I thought it wouldn't hurt.
B.
If you "report" your own post you will get a reply from one of the team.
A thread can be started by any current member. But, if it becomes a great thread then you have options; ask to make it permanent or convert the relevant information into a Wiki.
It might be better to go straight to Wiki if you intend this to be a tutorial.
jrockhead said:What about the speaker return? Should this also go to the center of the caps or back to the star ground? Sort of like a closed loop from the power supply caps to the amps and return back to the power supply caps.
speaker return to power supply is best. This way it has least chance to cause disruption......
But thinking about this reminds me how much more elegant balanced working is.
Yes, to the power supply is probably often a good idea. It should be drawn close to the speaker hot lead and power supply leads for the amplifier to minimize the created magnetic field though. It might cause ground bounce with symptoms like motorboating and increased distortion etc. if it is connected to the amplifier, but it should be possible to take it via the amplifier if input ground and output ground are separated on the boards.
- Power Supplies
- Single or dual bridge and why?
