Simply 3x gain preamp for OPA549
For the subwoofer channel on my 5.1 surround amp, I'm planning on using a single OPA549 (the other 5 channels are LM1875) as it will provide around 70-75w rms for my subwoofer.
However, upon searching the forum, people say that a gain of around 10 is the maximum you should use with the OPA549. But having said that, I'm only going to be using this chip for frequencies lower than 200Hz, so would using a gain of around 20-odd affect this region?
If it will, does anyone have a schematic for a simple circuit that will increase the gain from between 2x and 3x to use before the input to the OPA549? I've done searches of the forum, but they all seem much more complicated than I actually need (OPA627 buffers etc etc).
Thanks.
I dont think you will get that much power.
It should work with no problems
Thanks.
Try this
Max gain of OPA549
Hi: In response to the previous concerns regarding the max gain of OPA549 chip amplifier,after reading the TI datasheet i do not see any problems with using the chip with a voltage gain of 20+.TI does not mention any possible instability problems at higher gains.If someone has info to the contrary,please post a link to that information. Thank You Robert Cottiers
Re: Max gain of OPA549
It's not a problem... But it sounds like ****... Max 10!
Make an amp, and test it out...😎
Re: Re: Simply 3x gain preamp for OPA549
From the other threads discussing the OPA549, I was under the impression that was what I could get (I guess as a maximum rather than an average figure)?
I'll be using a 18-0-18 transformer and will be using a 4 ohm subwoofer, so what do you think the realistic power output would be? Either way, I think it will be enough for my fairly modest system.
opa549 can be supplied with max of +/-30 volts, whereas the opa541, +/-40 is allowed. these chips have a fixed bandwith, so that increasing the gain decreases the high frequency corner. but if you are using for subwoofer, then i see no problem with decreased bandwith, as you will not be needing it any way. i say go ahead and do it.
